Yes it has. The post you just read.One point which has not been considered is whether the boiler has been range rated.
SO it's a fixed figure?A 22mm pipe has a resistance of ~0.1 metres per metre length.
Drivel !
It depends on the flow rate
Which you got wrong before, now you have the resistance wrong.
No, that's wrong too. It's about 3m, but you have to allow for the boiler, valves etc.The 15/50 can handle a head of ~2m at 0.63 l/s
Well whoopy do, that's a bit obvious though, and having shown the pump is too small there's little point considering extra resistance.metres of 22mm pipe. That does not take into account the 15mm pipework and the resistance of the radiators etc.
Not having a good time are you.
Hailsham, someone (else) might look forward to you writing something which is not either
wrong, or
irrelevant, or
bleeding obvious.
