Well you wouldn't want a 9" joist going across your bedroom ceiling.yes but what does binder actually do? why it's sitting on top of joist?
If it sitting below joist then maybe I think of a reason it holds joists but why is it top?
Thank u
then how a binder solve this issue?Well you wouldn't want a 9" joist going across your bedroom ceiling.
It does what it says on the tin - i.e. binds them together. On their own they are more likely to flex. When bound together, each joist will gain adventitious strength from the neighbouring joist. A similar thing happens when solid bridging is used between floor joists.yes but what does binder actually do? why it's sitting on top of joist?
Because it would look stupid if it was below!yes but what does binder actually do? why it's sitting on top of joist?
