Structural engineer specified a Birtley CB90 lintel. Unfortunately I can't find one in stock near me. Best I can do is get it delivered within 15 days (approx.), which would hold things up too long.
I can however get Expamet lintels off the shelf, but can't check with SE at the moment whether they are OK.
Is there really any difference between these two?
- Birtley CB90 (2100mm)
- Expamet 75S (2100mm)
I can see the Expamet 75S is 15mm less wide, so maybe I should get an Expamet 95H (2400mm) and cut it it to length? Assuming they are identical enough to be used interchangeably.
