S
swidders
12 balls - all identical in every way apart from one which you are told weighs a different amount by a tiny fraction.
You are allowed to use a set of balancing scales three times only, at the end of which you will be able to determine which is the odd ball out and whether it is heavier or lighter that the others.
How do you go about doing this?
