until you find the answer we will leave this as a possible solution
I might do, if only I could learn to speak nonsense...jbonding said:I hope you dont speak on my behalf when im not around![]()
ban-all-sheds said:I might do, if only I could learn to speak nonsense...jbonding said:I hope you dont speak on my behalf when im not around![]()
jackpot said:Take 4 groups of 3. ( Called A B C D)
1. Measure A and B.......i....If A = B then Coin is in C or D
ii If A differs from B then coin is in A or B
Now you have 2 choices depending on the outcome above
2i Measure C against A or B......i.... If they equal then the coin is in D
ii If not then the coin is in C as we know that A and B does not hold the fake coin. Also on the scales if C is the highest of the weights then we know its a lighter coin. If its the lowest of the weights we know its heavier.
Third and final weigh.
3i The coin is in C or D so whichever group its in take 2 coins out and measure them. If they equal then the fake coin is the remaining one.
If they differ then look back at whether the coin is lighter or heavier and from the position of the scales you can see which one is the fake one.
Hope that makes sense......
johnny_t said:jackpot said:Take 4 groups of 3. ( Called A B C D)
I'd thought that, but there's a hole, I'm afraid. At you first stage, there is a 1 in 4 chance the fake is going to be in pile D - If that happens then you are going to go into the 3rd weighin without knowing whether the fake is heavier or lighter, and that makes your plan for the 3rd weighing fall down.
Sorry.....
jackpot said:johnny_t said:jackpot said:Take 4 groups of 3. ( Called A B C D)
Sorry.....
Not sure i know what you mean. If at first stage you know the coin is in either A and B or C and D. You would then go on to the second stage. I used an example with the coin being in C and D. If it was in A and B then you would reverse the measure i.e intead of measuring C against A or B you would measure A Aigainst C or D. And only after this 2nd stage will you find out whether coin is heavier or lighter.
I think......
