I know there are probably a million and one people asking about overflow pipes....but....i dont think this has been covered.
Ok. The problem: streaming of water out of the overflow pipe (from upstairs). So one of the tanks in the loft is overflowing.
A plumber has changed the ballcock in the larger (cold) water tank. The smaller hot water tank (which is a bit of a pain to access - daft location) seems fine.
Despite this change of ballcock the overflow problem still persists. And its definitely the cold water tank overflowing as everytime i get back from work i can see water pouring out (of the flow pipe), so i go into the loft and sure enough its from that tank.
I have tried turning the heating off to see if that affects anything. No difference at all.
The water in the tank is clear (apparently it would be dirty if water from the tank in the airing cupboard) was somehow getting in there.
I just dont understand where the water is coming from to fill up the tank?
By the way if this sounds like i dont really have a clue about these things then you'd be spot on!!
Any advice at all??
Thanks,
JJ
Any advice at all??
Thanks,
JJ
