Last night whilst cooking fathers day dinner of roast lamb and roast potatoes + veg the cooker went BANG and tripped the RCD and local breaker. Found the glass dome cover over the internal lamp had shattered (spraying my dinner with glass) and the lamp inside had separated (glass bulb had come away from brass collar). I ordered the glass dome today from Baumatic and thought I'd replace the lamp simple enough. Got home tonight and changed the lamp only for it to go BANG again. I've removed the top and took the lamp holder out. It's a little black inside but the connections look OK.
I put a 25W 240 MES oven lamp in and tested with a multimeter & got a reading of 180 ohms so guessing it's about right (ie not a dead short). Tested a normal 40W 240V bulb as a comparison a got 110ohms. Tested the oven light circuit with no lamp in and all is fine. Powered up cooked with no lamp in all is fine. As soon as I put a lamp in the holder... BANG!!
So several attempts later no further forward....
What am I missing here.....should I just buy a new lamp holder from Baumatic as well...???
Model: Baumatic BT2391SS (gas hob-electric oven)
Fed Up now......
Fed Up now......
