I've read about how to make sure the room is ventilated and I recently unblocked the external airbricks that Millfold kindly filled with silicon when they alledgedly installed cavity wall insulation.
It has made no difference.
The worst of the black mould is where the ceilings upstairs join the walls. Our house was built in 1946 and it was considered a good idea back then to put the ceiling very high into the loftspace, thus creating a slope where the ceilings meet the outside walls.
The loft is wel insulated, but it is not easy to see what is stuffed, or not, in the gap between the roof felt and the upstairs ceilings around the outside walls.
My logic says that this gap should be left open, but then this is an area where cold air on the loft side of the plasterboard is causing condensation on the other side of the plasterboard, in the upstairs rooms.
Should this sloping gap be insulated or left?
