We just had a new tap fitted, Blanco Nelson Monobloc (pull out), nice tap but the hot side is really low pressure.
The old tap was fine and every other tap in the house is fine too .
I've managed to prove the hot pressure to the tap is fine, because when I remove the head from the tap by unscrewing it, the hot water pressure is absolutlely fine, splashing all over the shop!
However, as soon as I screw the head back on the hot pressure is really low again.
I should say cold water pressure is fine.
Is there any way to adjust the head or am I stuck with really low hot water pressure?
Cheers
Cheers
