- Joined
- 25 Aug 2011
- Messages
- 43
- Reaction score
- 5
- Country
hi , if you cannot turn off the oil feed at the tank it sounds as if the spindle is broke
not to worry you can install a new tank iso at a later stage
as for cracking the oil line nut at the burner and getting oil that is good
it sounds like you have a small bit of air between the black iso tap and the fuel pump on the burner
try to start the burner , if it locks out , wait and reset approx 30 seconds later , do this several times and the burner should fire for you as it will push the air out of the fuel pump
