If you fit £600 worth of heat exchangers to a mucky system you could end up with same problem again in a few months. I rarely find blocked primary heat exchangers, secondary is common to block up though.
Guys sorry i've not got back on line but the noise has been gradually diminishing and it has now completely disappeared. So what do I do now - get the boiler serviced by a (different!) competent plumber or do I leave well alone and keep my fingers crossed?
Pemba
ps what is the best boiler around these days if/when it does give up the ghost?
