I have an oil-fired Boulter Classic boiler, sealed system. The pressure of the system is going right up and then right down - exactly as would be expected for a faulty pressure vessel....except that there is nothing wrong with it, I've had it checked by an OFTEC engineer. I read in the FAQ that this problem could also be caused by a blockage in the pipe between PV and boiler:
1. Could someone step me through the procedure for checking this ( i don't want to just disconnect the pipe without knowing what I'm doing)?
2. Any other ideas of the cause of this fluctuation?
3. Could a leak in pipework cause pressure to go too high as well as too low? I am not over-filling the system when topping up.
Many, many thanks.
Many, many thanks.
