Bluetooth dongle on Smart Tv
Just checked and mine is A 2 IN 1 device. So the last thing left to try is the phono cable instead of the jack. Thanks for the assistance
Ok, so I tried with the phono cable but strangely, the TV only has the red phono output and no white?
It can't be an AV output then - needs R&W - left and right what is the model number of the TV - I'll see if there is an online manual...
The TV is Spanish, bought in El Corte Ingles in Madrid. I think it is an INVES LED-500 4KSMT 4K Ultra HD Smart TV but I doubt you'll find a manual, and less in English! But I appreciate the gesture. :)
Conexiones
3 HDMI
2 USB
1 AV
1 VGA
1 Audio
1 Auriculares
1 Coaxial
1 Ethernet
You're right. What I would do is connect the soundbar direct to the TV with a cable and see where you are getting audio from. Whatever is producing audio output should then connect to the bluetooth transmitter (if there is a switch make sure it is on Tx) and should pair with the soundbar. Good luck, I think that's about all I can offer!
You plug the dongle into the USB so it has power, you can do this and sync it from any USB socket.
To sync it you usually do it within x number of seconds of powering it up or hold down the button on it - both while your other device is in sync mode.
The jack lead goes into your headphone output.
I appreciate the reply. However, there is no button on the dongle. I will look into the advice you've suggested though, simply because, as always with new technology, we learn something new everyday, and there may well be some of what you are saying that becomes useful once I give it all a try. Thanks everyone.
