J
johnheritage
Funny you should say that, because I ended up getting my 60 year old + mum to hold it and... ta da.... it's up. It's all about co-ordination and care, with some effort.
I've used a clampable prop before and done them on my own, and was going to get one, but figured it wasn't worth the money for just two boards.
I used the thru fixings tonight.
Richard is correct that the best time to get those in would be as it hits the firm but not off stage.
My DnD was clearly not holding tight when I drove them in with it 100% set. So it's now acting as a shim in my opinion, and will be getting quite a few fixings through it.
You can tap on the boards with a pen to find the solid spots - pens work better than knuckles.
The boards transmit the drilling too rigidly and cracks it free of the DnD easily - specially with the hammer on near the sides.
You also need to use the correct sized bit!
I have a bunch so I tried 7mm on anchors that suggested 8mm, too tight. I did so because some of the 8mm holes were a bit loose for my liking.
I would suggest you switch your hammer off when going through the board it's self, as the AquaPanel tend to countersink themselves, in quite a bad way, with the hammer on - the fixing will go clean through the board as it does up.
I also bought a Hardiboard and (from my experience of one board), I prefer those. The aquapanels are kind of like loose, flaky aggregate and that webbing is there to keep it consolidated.
The hardi's are so fine grain, they don't need it. The surface is smooth as a baby's bottom. Little bit longer to cut. Haven't tried putting anything other than drywalls thru it, but I suspect it'd produce a nicer finish with the thru fixings too.
The Aqua's are more like chipboard, whereas the Hardi's are more like MDF.
