Hi guys,
I'm hoping if someone can please advise?
Spec:
3 bed semi
1 bathroom (we only ever use power shower (salamander pump))
2 d/s rads
4 u/s rads
Mains output is fairly low
'Generally', only use one hot water source at a time
Cold water tank, and small (c/h?) tank in loft.
4" loft insulation, filled cavity walls
My current boiler (a perfectly working Myson Apollo), is located on an inside wall in the kitchen, with I think a flue going upstairs and out through the roof.
Due to a prospective new kitchen in a few months, I think it is a (begrudgingly), good opportunity to replace the boiler and move it into the airing cupboard upstairs, as we will most likely knock the kitchen through.
Q. We are not tight for space in the loft and don't ever intend to try and turn it into a liveable space- is it best to stick with a regular boiler, or is there any advantage changing to a system boiler?
Q. The airing cupboard is on an outside wall, but as the flue is going into the loft, should the connecting up work be minimal as any flue extension can just be connected to the existing flue?
Q. Is it appropriate for me to request to see the what I am being charged for the boiler alone, and if I am able to source an identical one cheaper, is it acceptable for me to supply said boiler?
Q. I'm on a tight budget, so any recommendations on good spec boilers would be appreciated.
Sorry for the long post, I hope someone is prepared to answer some of the questions, and thank you in advance!
Also, ballpark figures for this (I'm in the South East)?
Spec:
3 bed semi
2 d/s rads
4 u/s rads
