If casing seal was breached the effects of flame impingement (CO) would circulate back through fan INTAKE resulting in POC leak through 'leaky' case seal , much like the 'snowball effect'.
Of course it can snowball, but but that happens via the outside of the boiler, because the pocs ARE sealed from the fan intake, inside it. You're looking for seals in the wrong place. After the flames, there are seals to the inside of the case, so it's not reliant on the case seal.
It also happens via the holes you get when prima/profile flues corrode through near the end, but that's a
fault.
You don't get flame impingement
as soon as the case seal leaks. Positive case pressure boilers like Netaheats were designed with an allowance for case leakage - through grommet holes etc. Try your FGA round those.
As I daresay you now, a profile won't run with the case off because of the aps, but if there's just a small rust hole the FGA readings are normal.
Starting back in CORGI days they said look for case seal leaks with an FGA, before smoke plumes came along.
I used to put a smoke bomb in the inlet - Netaheats always leak smoke and stink.
The point about the small red arrow though is that it happens even when there's NO fault in the boiler. It's almost impossible to separate the inlet and exhaust, though they tried harder on the Netaheat after they'd killed a dozen or so. So you can't avoid some of the pocs coming back in the flue. That's the same on a -ve case boiler, but it doesn't come out via any leak so no matter.
If you want to measure it you can't use Oxygen, you have to use CO2 or CO, though there may be very little CO because they're set up with a lot of Excess Air.
Think for a minute what your 20.9% O2 in the inlet would go to if you had say 150ppm CO, (ignoring the CO2 for a minute) it would go to 20.885%. Would you guarantee to see that difference?
If you have
enough air leaking out then sure, you're depriving the burner, but the problems start way before that happens.
So, your first post with its "facts" was way off - and I though "Oh no it's him" after the other thread....
Truce?
