There are hundreds of posts about boilers cutting out when they should be on but my problem seems fairly unique. I have a conventional boiler which works perfectly most days - until the weather turns abnormally cold. Then the boiler will simply go off and not come back on even though timer and room thermostat says it should (I have red on light on the timer and a flame symbol on the thermostat.
Some suggestions to the general problem are that the boiler is overheating and the safety cut out has been activated but I can feel the reset button and it has not popped out. But it sort of makes sense that it is something to do with when the boiler has more work to do without a rest (i.e. on coldest days).
It was very cold outside yesterday (-5c) and the boiler was ok for the morning (fired up for 2hrs) and then at lunchtime (about same period). But it came on for its evening period and then cut out after 50 mins. About an hour later it came back on but then lasted another 50 mins. Then it remained off for at least 2 hours before coming back on. Room stat never got to its cut out temperature.
If it was a faulty pump, timer, thermostat, motorised valve, boiler PCB, low water pressure, blocked vent, sludge, etc all of which are suggested as possible causes to the general boiler cut out problem - it would not explain why it has worked perfectly today when outside temp is +5c but could not keep running yesterday when it was 10 degrees colder outside. Also most cut out problems reported here seem to occur much quicker and/or report the boiler constantly cycling off/on every few minutes.
Any bright ideas?
Any bright ideas?
