Thanks all for the responses. I had not received any new email notification of responses to the thread and so had assumed there had been no further response.
It sounds like I will have to ask my plumber to investigate but I would really need him to come out in a sustained cold spell. Even then I could struggle to replicate the problem at the precise time he is here. Even when the problem exists, an hour later the boiler can fire up again. Predicting the timing of the problem and my plumber's availability is challenging.
I am not in an area of extreme cold but even in the south of England it was -5c overnight last week and sub zero all day. Then next day 10c warmer then back to very cold again and now back to +5c over the weekend. CH behaved itself perfectly on warmer days but cut out on the cold day.
The boiler and gas meter are in a garage which is part of the house and so not that cold. No issues with any other gas appliance - hob and gas fire.
The problem I feel is some form of thermal cut out arising from extended use of the boiler on cold days. Generally when very cold the normal twice a day programme is insufficient to reach 20c (the temp drops overnight to 16c on room stat). So when between designated heating periods my wife will press the override button. That works but in fact tends to mean it will cut out sometime later. On warmer days my wife is not inclined to do this or the 20c temp is reached and the room stat turns off the CH.
I will see if I can more readily replicate the problem even on plus zero days by turning CH to continuous and raising the room stat temp to force it on for longer.
I did turn up the thermostat on the boiler - also I felt the knob turned a bit too freely so will have my plumber check that this control is working correctly.
