You remove the pipes from the hydraulic unit on the left.
First remove the two wire clips, ideally with forceps.
Then loosen the two clamping screws about four turns.
The pull the unit towards the left until it exits the clamping part,
The gently rotate it a few degrees in either direction untill hopefully the seal is loosened and the two pipes can be withdrawn.
On reassembly silicone grease in the sockets and on the "O" rings will aid reassembly.
Tony
Tony
