Hello,
I am fitting a new kitchen in my house. My combi boiler is in the kitchen exposed on one wall. It has a number of pipes coming from the bottom, down to the ground. I am going to box these in with timber boxing. The boiler’s electric is provided by a plug on the end of a flex. The closest plug socket (single) is on the next wall 90 degrees to the boiler wall, under where the new sink will go (is the position of the socket under the repositioned sink an issue?).
The problem is that the flex is too short to reach the plug socket. I intend on running the flex in the boxing I will put around the pipework, then along the floor (a few inches up?) and round to the single plug socket under the sink. I would like some advice about whether this is suitable, and what would be the best way to extend the boiler flex (junction box in pipe housing?)? I appreciate that with this being in the kitchen there are part ‘p’ implications. If need be I will have to get a registered sparky to help, but I would rather do myself (to minimise cost). I am pretty competent with basic electrics, and have already changed lighting and extended rings/spurred elsewhere in the house.
Also a washing machine will be housed next to the sink, so I would like to use the same plug socket for that. I think the socket is a spur, but I was hoping I could substitute this with a double socket myself without having to involve a sparky?
Any advice would be much appreciated.
Regards,
James
Regards,
James
