Boiler flame keeps going out
n2w
5 Dec 2011
Birmingham
Hi All
I have a Worcester 28I RSF Boiler quite old
it has started to have the following issue
We turn the heating on/or shower or both and it works fine for a period of time then the house/water gets cold we realise the radiators are cold or get very cold in the shower.
When i get to the boiler it has no flames or pilot light on but the fan is spinning and it sound as if its working just no flame.
If I power the unit off and back on it all fires back up and may run for a few minutes or a couple of days before the issue happens again
The pressure is at 1bar
Any ideas how to fix this issue or what is the casue
All help appreciated
Neil
Last serviced about 10 months ago
Worcester say they think it is either the Boilers Primary Sensor or its Circuit board
Well obviously you need someone to correctly diagnose the fault !
I know that plumbers are thick and fixing boilers must be very easy.
Even so I expect that you are going to need an engineer unless you want to change all the parts one by one until it works again.
Tony
Call out Worcester for a fix price repair. Making sure it is working nicely for the coming cold weather. Priceless :mrgreen:
Andy
