whereas the right hand one does nothing.
Is this normal behaviour or are we getting closer to a cause?!?!?
Nail on the head!
YOUR MINIMUM GAS PRESSURE NEEDS RESETTING ITS A VERY COMMON FAULT .GET A SERVICED ASK THE ENGINEER TO CHECK IT .IT SHOULD BE 2.5 MB
Just thought i would give you a quick update.
Since my last post, i have vacuumed inside the boiler including the gas burners, and set the timer so that the boiler has about 6 hrs rest during night as it was on 24hrs before.
Since then it has not locked out once !
So at the moment all is well.
thanks again
Carl
