That’s the ABV isn’t it? Automatic Bypass Valve. PRV is a pressure relief valve that lets pressure off before things go bang!Hi Ian,
Why is that? Both 2 way valves are closed as the heating and hot water aren’t calling, so the prv allows the water to circulate back to the boiler as I understand it/was told by installer?
my guess is that the frost stat has not had the front dial put on in the right place. might say 5 degrees but is probably coming on at a higher temp. check pipestat but reduce to 15 degrees.
it also need the wiring altering. the froststat and pipestat arrangement should be altered so that it opens the heating 2 port valve. this way when they do activate the pump sends water from the house at about 20 degrees and it turns off very quickly
you mean the automatic by pass,ABV, the PRV is the pressure releif valve it vents water to outside if there is a failure on the system, not the same thingHi Ian,
I don’t actually know where the bypass valve is from memory. I’ll have a look in the garage tomorrow as I assume that’s where it is.
I thought whilst the heating is clicking on and off on a cold night like tonight though, that the system should be warm enough to not have the frost stat kick in several times an hour?
