Hi, I've got a Glowworm boiler (not combi) in garage with a frost stat beneath the boiler itself.
Since before Christmas, the overheat stat has been tripping quite a few times with F5 on the display.
I've thought I'd narrowed it down last week to a problem with the frost stat, which I replaced but the problem remains....
If the boiler fires up normally for hot water and/or heating, everything is fine, the temperature display on the front of the boiler will slowly rise up to required temperature.
If I dial in a temperature on the frost stat myself to test it so that it kicks in, the temperature on the front display of the boiler immediately rises to above 80 deg, there is a banging /gurgling noise from the boiler and the boiler shuts off.
I'm assuming the really cold weather we had overnight Christmas was causing the frost stat to activate and shutting off the boiler and no water/heating the next morning until the reset was pressed. Additionally I was woken some nights with the pipes banging/gurgling.
This doesn't happen with normal heating/hot water, everything is quiet and works as it should.
Any advice what may be the cause please?
Thanks.
Thanks.
