hi lads wonder if you could help ,my fatherinlaw has just had a worcherster 24 ri regular boiler fitted as a straight swap and the plumber has used 15mm pipe to feed the gas .It reduces from 22mm about 18 inches (the other side of the wall) to 15mm then to the boiler which it is then enlarged back to 22 mm to go into the boiler ,what do you recon .....as im a qualified plumber and no a bit i no on a 15 or 18 kw boiler it is possible to do this for a short lengh but not sure on a 24kw model.
