I have an Ideal Mexico Super CF 80 Propane boiler.
The unit is running for ten or fifteen minutes at a time. The boiler shuts down and the pilot light goes out. I can restart the boiler almost immediately and it will run for a short period again until it shuts down again. I hear a click from the boiler as it shuts down. When running everything is operating normaly.
I have had the gas supply checked and a new regulator fitted because I thought the problem was worse when the propane gas tank was low or the outside temperature colder. All this had made no difference so the indications are it is the boiler and not the gas flow.
Any ideas where /what I check next?
Thanks for help
Regards
Mike
Thanks for help
Regards
Mike
