namsag - There are only two leads to the gas valve therefore I assume I set everything to 'On' and check for 240V across these terminals? But how do I check if its "breaking down under use"?
Measure the coil (gas valve) resistance cold, then when the boiler cuts out, disconnect power and measure it again before it cools - bet it goes open circuit.
If you keep probes on the 2 connections and are still gettin 240v and the boiler stops firing it can only be the gas valve faulty. I f you lose 240v your fault is elswhere (with boiler stat bridged out as you have done previouly)
OK guys here's the results so far. My wife beat me to it - got home to find she had contacted someone about it and he arrived. I explained everything and he immediately suspected the solenoid. He also reckoned the pilot light although not causing the problem looked weak. He stripped out the pilot burner and cleaned it up. Had a solenoid with him so fitted it but no change. He now reckons the gas valve itself is faulty so will get one tomorrow and fit it. I'll report back when this saga is solved........
Agile . the guy has bridged stat out and its still doing it. And mexico doesn`t have any sort of interupter. So unless he has not bridged stat out properly it can only be the gas valve or a lose wire between stat and valve
Finally got this resolved - gas valve (not the solenoid but the actual valve!). Now have lots of heat and hot water - thanks for all the advice -bring on the winter.....
