B
BigBurner
My plumber came back this morning and said the gas pressure is now working fine. But there is still the problem that I only get hot water when I turn the kitchen sink on full (hot water is fine when I turn the tap half way when the heating is on) and I get luke warm water when both showers are on simultaneously. He assures me that these are faults and the boiler should produce hot water when I turn the tap on half way and there should be no drop in temperature or pressure when I use two showers at once. So he has called Worcester and they believe that there may be a problem with the diverter valve or heat exchanger and they are coming on Thursday.
He did point point out that at the boiler, the incoming mains is 15'C cooler than what Worcester recommend but he said this should not cause the issue of me having to turn the sink tap on fully to get hot water (it's freezing cold unless I turn the tap all the way).
This could have been gas mains distribution problem (maybe now fixed) or a sticking regulator and may re-occur. The Transco man was wrong, it was regulator/distribution problem.
15C cooler? What does that mean? It is probably between 7C and 10C incoming. That means 20 litres/min flow at 42C to 45C tap temperature.
Once working properly you will not be disappointed. I hope he put pressure equalisers on the showers and balanced the hot and cold water system. A dishwasher does not need full flow, a shower does.
