In 2009 I posted this thread about my Worcester Bosch boiler, that was 9 months old and was increasing pressure with the filling loop disconnected.
https://www.diynot.com/diy/threads/pressure-increasing-on-a-worcester-combi-boiler.166884/
Opinions ranged from internal holes, corrosion between the dhw and chw waterways and corrosion due to a lack of inhibitor and to bleed the radiators for gas and add more inhibitor despite me already putting a nail in the Magnaclean, which had already came out rust free. The system clearly settled down, as I stopped posting to the thread and in fact forgot all about it.
Forward to 2023, when my one year old Ideal Vogue had its first service. I noticed that after the service the pressure was creeping up by half a bar with the filling loop disconnected. After testing the inhibitor using a Sentinel test kit my X100 was under strength so I added a bottle via the Magnaclean and drained water from the rad to reduce the pressure by half a bar. This I had to do more than once, as the pressure kept creeping up. It then settled down.
Last month my boiler had its second service where I asked the engineer not to increase the pressure, as I run the boiler at one bar cold so he didn’t touch it. After testing the inhibitor again after he had left I found it was again under strength so I added another bottle again via the Magnaclean without touching the filling loop and then run the system for 30 minutes to circulate. The boiler then settled back to 1 bar when cold. 3 weeks later it is at 1.4bar. The heating hasn’t been on since running the boiler for 30 minutes. Yes well within limits but there is a trend here where on two boilers the pressure increases for no reason, this time after 2 services. What is going on, as this is a repeat of 2009 and last year?
