I have removed 1.4 litres of water to get the boiler down to 1 bar again and have isolated the CH by turning the valve off allowing me to keep the hot water on. I will now play the waiting game and will report back if the pressure changes in the coming days.
So it is now 5 days later. The pressure gauge increased by 0.1bar, which might be the natural tolerance of the gauge. I then turned the two valves on at the bottom of the boiler to reconnect the CH flow and return. The gauge didn't flinch. This was after having to drain 1.4 litres from a radiator to maintain its normal off pressure the week before.
What I did notice with the CH isolated, was that when HW was called for, the pressure gauge would increase by around 0.3 bar while producing hot water.
I have now called for heat, which produced a major gurgling sound from the boiler, which lasted a good 60 seconds together with a whooshing sound. This sounded like the boiler was filling up with water even though it was not and reminded me of the boiler being filled for the first time on installation. The sound transferred or maybe it was duplicated to a downstairs radiator that also sounded like it was full of air. This was after bleeding the radiators before isolating the CH after adding another bottle of X100 on top off the original 2 bottles that was added when the system was installed in 2022 with an additional bottle added last year, as it was testing under strength.
So the questions are:
1/ Where did this 1.4 litres of water come from (see thread) that I drained last week, seeing the filling loop on the boiler is disconnected on one side and is it still an opinion that the expansion vessel could have a pin hole?
2/ Why did the boiler gurgle loudly after being isolated for 5 days?
3/ Why did I have to bleed the radiators again of a little air but not enough that stopped the tops of the radiators getting hot?
4/ Can air circulate that bleeding just doesn't remove, as I have had this gurgling last year in the same radiator that just stopped making a noise after a while.
5/ Is it normal for the boiler to show an increase in pressure with the CH isolated when the hot tap is run?
6/ Is there a link to my problem in 2009, as per my first post of this thread?
