I have a Baxi Duo-tec 40 Combination Boiler installed in June 16. It loses pressure every night. We top up the pressure to 1.5 bar in the morning and the heating runs fine without a loss of pressure until the heating goes off late in the evening. 1 hour later the pressure has dropped below 1 bar and in 2 hours it is 0 bar.
The Baxi engineer has been out twice. He replaced the factory fitted expansion vessel which he said was the wrong size for the boiler and fitted a larger one. He checked the pressure release valve.
There is no sign of a leak. I have had a plumber out who has checked all visible and under floorboard pipes and used a thermal imaging camera to check a few feet of underfloor pipe but cannot detect a problem. There is no sign of damp and yet this much water loss would surely be showing somewhere?
I don't understand how, if there is a leak in the system, the pressure would be unchanged throughout the day when the heating is on and only drop once the heating goes off.
Any thoughts on what to try next?
