i can see that it would press the outside of the vessel on most of the sides, but what about where the bag meets the half of the PV which is filled with water? If I leave the drainage valve open when I pump, then the water, as I inflate the bag, is pushed out, so in principle I can keep on filling the bag up with air until it either 1) inflates to the full capacity of the bag or 2) inflates to the full capacity of the PV - I don't know which is bigger. My point is, how do I know - if the PV is normally part full of water and part full of air, and I am pumping air in one end and water out of the other (because the drainage valve is open) - at which point the pressure of the air in the PV is accurately displayed, since effectively there is always an outlet for the water and therefore a lack of resistance against at least one wall of the runner bag? maybe I am over thinking it. I really just want to know whether I did right to
1) open the drainage valve
2) pump air in until the pressure on my gauge and the boiler read 1bar
3) close the drainage valve without letting any more water run out (I had lost a lot less than the 10 litres touted in the FAQ)
Thanks chaps
Thanks chaps
