The op wants to install a variable speed pump so he can erm vary the speed, variable speed means variable flow rate , not so good on a boiler that needs 28lpm flow through it whenever its switched on.
You can set a few modern pumps to either fixed or variable speed.
The OP's boiler doesn't have pump overrun, so the pump stops as soon as the boiler goes out. There is no flow when the boiler is off, so the question of minimum flow when not alight does not arise.
I did think that, but a slower pump speed would only lengthen the off time.Just because the burner is off doesn't mean the pump isn't running.
Yes, that will happen if the boiler stat has turned the burner off, but there is still a call for heat from the room stat & programmer.Just because the burner is off doesn't mean the pump isn't running.
What's wrong with that? Provided the water temperature is above the room temperature, the rads will still be giving off heat. I don't know the hysteresis of the boiler thermostat, but its typically about 10C. So if the burner has gone off, but the pump is still running it will only take a few minutes for the water temperature to drop; the burner will then relight.I did think that, but a slower pump speed would only lengthen the off time.
But the OP specifically was asking about the system flow rate through a bypass when both motor valves were closed.
With both motor valves closed the boiler should not be lit !
No he did not.I don't want an ABV as pump is going to be a variable speed variety.
No he wasn't.
But I did read that table as the required flow rate when burner is lit.
What about minimum flow rate to protect against overheat, when the burner is off?
Basically, I'm trying to size a suitable TacoSetter inline valve..
Current pump is Grundfos UPS 15/50 with fixed bypass (gate) valve.
