Boiler moved by a guy that isn't Gas Safe registered.
All you need to find an installer close to you is your own postcode!
You then compare the names the search returns with the name you have been calling him by.
Tony
What are the regs regarding the placement of the PRV outlet and condensing outlet? He has place the former directly above the latter. So in the event it 'trips', it'll drip directly onto the condensing pipework. Is this a problem?
He also hasn't turned the PRV outlet back to the wall.
It was a semi loaded question.
I live 30 plus miles away from Tony; yet have hundreds of customers within walking distance of his laundrette.
The Gas Safe system is very floored in this respect.
Recent news article:-
A Buckinghamshire tradesman has been jailed for nine months for illegally carrying out sub-standard gas work at a Milton Keynes home.
Chris Johnson, of Milton Keynes, installed a boiler at a property on Armourer Drive that was dangerously defective because it was not properly connected to a flue.
The heating fitter was prosecuted (19 July) by the Health and Safety Executive (HSE) after undertaking the installation without being accredited to the Gas Safe Register – a legal requirement for anyone undertaking gas work of this nature.
Amersham Crown Court heard that concerns were raised about the quality of Mr Johnson’s work when the householder returned home from work in July to find the boiler wasn’t working.
Gas Safe and HSE inspectors subsequently visited the property on 20 July 2012 and identified a fault with the flue connection, classing the boiler as unsafe.
The court was told that carbon monoxide fumes could have seeped into the home instead of escaping through the flue, and that this could have had devastating consequences.
An investigation established that Mr Johnson was not registered with Gas Safe and had worked illegally as well as unsafely.
Chris Johnson, of Bogart Place, Oxley Park, Milton Keynes, received full, concurrent custodial sentences of nine, eight, six and six months after pleading guilty to a breach of Section 3(1) of the Health and Safety at Work etc Act 1974 and three separate breaches of the Gas Safety (Installation and Use) Regulations 1998. He was also ordered to pay in £2,480 in compensation to the householder.
After the hearing, HSE inspector Graham Tompkins said:
“Chris Johnson installed a gas boiler and gas pipework knowing he was not competent or legally allowed to do so.
“People die from carbon monoxide poisoning because gas appliances and flues have not been properly installed, maintained or because they are poorly ventilated. Badly fitted and poorly serviced gas appliances can also cause gas leaks, fires, explosions.
“Homeowners, landlords and tenants should always request ID and check their engineer is properly accredited.”
Russell Kramer chief executive of Gas Safe Register, added:
“Every Gas Safe registered engineer carries a Gas Safe ID card, which shows who they are and the type of gas appliances they are qualified to work on".
The Gas Safe find an installer generally works well.
But sometimes it does seem to exclude some people.
Did not find Dan in NW10 but don't know where he is registered at.
Tony
It will exclude people and businesses who haven't agreed to be 'found' by the search. It doesn't automatically include every registered business.
That must have been what you done the other year Agile when you didnt appear on the GSR site ;)
OP - Just to throw another spanner into the works...what boiler do you have? If it's a non-condensing one then moving it was illegal anyway, registered fitter or not, as it technically counts as a new installation and you can't legally install a non-condensing boiler any more. As for getting it signed off by another engineer, best of luck with that, it's also illegal to sign off someone else's work.
