P
penfold321
it is now suggested the pcb needs replacing and it is not the pressure switch or the gas valve
Who has suggested that? Not ANOTHER RGI you have called out.Or are you a member of various forums?
Mr. W.
the second engineer he thought it was the pressure switch first time round
Penfold i hope you dont mean me by its now the pcb i
What i said is it is occasionally the board as 2 mins in front of boiler would confirm what the fault is but its definitely not APS as has been suggested.
Edit jumped in as you replied and what makes him think that what tests did he do
So, have you now got a shiney new pressure switch in your boiler which you didnt need and now it still doesnt work?
Mr. W.
All that neds to be done is when pilot is established check the main solenoid for 240 if its there then its not the board.
Lets put it this way he missed a basic thing by thinking it was the APS
had another engineer out this morning he thinks it is the pressure switch so i will have this done first as it is a lot cheaper and hopefully this will work.
So, (since your new RGI arrived this morning) the above statement is incorrect, or in the 4 odd hours he has been at your property he has gone and bought a pressure switch, fitted it & now back to square one?
If not, what has he has been doing all this time, as at around 2pm you report that he now thinks its the PCB?
I'm confused, but then again it doesn't take a lot with me![]()
Thats a good lot of head scratching time betweem his 1st diagnosis of a faulty pressure switch. Or has he been on other calls - I would have hoped so as your in for a mighty bill when this boiler finally gets repaired, if he has not.
APS Air Pressure Switch
When he arrived he first said he thought it was a pressure switch and had a spare one and went to get that which took two hours then came back tried it no difference so back to square one then he reckons it is pcb went to get that 145.00 + vat and i am still waiting for him to come back (i have not paid for any thing yet)
Mr. W.
lol.. the engineer never came back! Thats why it is important to have places like this forum because when you ring a gas engineer and a cow boy turns up you can pre-arm yourself with a bit of knowledge when the cow boy starts to babble.
