N
namsag
Looking at your picture pump is wired from your boiler so for pump to be on power is getting down there so as has been already said no problem with the programmer.
As for operation of boiler first thing that should happen is the fan should come on you should be able to hear this if you can`it is prob shot, then because case removal is required to check this you should get someone in.
But if you do remove case via the 2 screws after bottom panel removed you can check for 240v at fan connections if its there and fan not running it`s new fan req if no 240v it`s probably the board.
