Let's hope you are correct.Ok, I might have managed to fix it.
That's probably OK. Unlike the older, mechanical stats, which keep the boiler running flat out until the set temperature is reached, the DT90E starts switching the boiler on and off as it approached the required temperature. This prevents the room temperature exceeding the set temperature, which often happens with mechanical stats. The room temperature is maintained within much closer limits.The only thing was I requested 23, and it switched off at 22.5 (little flame on the thermostat went out). Is this normal/ok?
Monitor the situation and come back to this topic, if you still have problems.
