I have a Myson Economist 60/80 S Plan system which has started to occasionally overheat shutting off the pilot light. Seems to occur only when pump stops when boiler is flaming at max output. Boiling/rumbling can be heard in the heat exchanger as there’s no pump-overrun and the overheat sensor trips shutting off the pilot light
Boiler temp has been turned down to 2.5 which reduces occurrence. Test meter on boiler output pipe indicates boiler stat works fine as temp cycles never going above 58 degC on setting 2.5.
System is clean having new pump, power flush, inhibitor/noise reducer additives last year.
Any suggestions on what could be causing the problem. It's worked ok without a pump-overrun for many years?
Can a pump overrun feature be fitted? Can it be as simple as pipe thermostat fitted adjacent to the pump keeping the pump on till water cools. I am concerned with both valves closed is there going to be enough flow through the bypass as its a gate valve that's barely open. The system has no TRV's and hence no pressure bypass valve.
Any advice appreciated?
