You dont to seem to have any flow during the over run as the differential should be down to just 2-3 degrees.
Are you sure the auto bypass is fitted the right way round ???
Tony
The auto-bypass valve (Honeywell DU144) has been tried on highest and lowest settings.
Any ideas please?
Tony
That and set correctly
Have you checked the impeller of the pump? You may find it blocked and unable to produce enough flow to lift the auto-bypass. Set the speed of the pump to 3 also.
Unless you remove the pump head and check the impeller you'll never know what to 'think'... Power flush and blocked impeller go hand in hand I'm afraid.
I've just watched the auto-bypass not flow. The rad valve closed. Temp above the bypass went to 63 deg C, below was 51 deg C.
You have explained very well why a 2 two port valve layout [S Plan] is such a bad idea.
