Am I right to say that the pump feeling so hot is because the motor is overheating rather than the hot water is getting stuck there?
Ah, you beat me to it with your edit... Thanks
yes, then get them back to turn the pump body down so the screw is facing you (facing out)
ok i'll try & guide you through it because you need some hot water, turn off the power to the boiler/pump put some towels under the pump, now you can either turn off the two valves either side of the pump or leave them open, take out the big screw in the middle (you will get water coming out) under the screw you will see the end of a shaft (you might need a torch) put a screwdriver in the end & this shaft should turn, if it doesn't then the impellor is stuck, now you can either perceiver turning to turn it or you can turn the power back on & try to turn it, if neither works then someone is going to have to take the pump head back off to free it, which is best left to an installer & not the fool who fitted a WB pump head he happened to have floating around in the back of the van
Hit it with an hammer!
Either way I'll get in touch with the landlord and see if they'll cover the cost of me getting Homeserve etc out to take a look at it. They're a small company so they only have 1 guy as far as I know. The same one who came to "fix" it a week or so back was the one who wrote about the new fan in 2009...
Cheers
Duane
