- Joined
- 11 Dec 2024
- Messages
- 2
- Reaction score
- 0
- Country
Hello
I have a glow worm flexicom 15hx boiler and a month ago, it showed a fault of 22, I reset it and it worked again, but then went a couple of times again, and showed fault 22, so reset, and showed fault 25, it worked on and off for a month but had to reset it a few times and then it went completely today showing fault 25 flashing. kept trying to reset but back to f25.
called a boiler engineer out and he reckons its the circulation, he went upstairs and said my actuator is playing up but did something and got it working. He said if it happens again I will need a new actuator. what I cant understand is if its not a combi boiler and I need the hot water tank, he said the hot water tank is not connected to anything? yet it was put in 9 years ago and never had any problems before, has it got to be connected for the boiler to be able to work? or is that if I wanted to heat the water tank with the electric switch for hot water if I wasn't using the boiler. is the tank only there because it needs to hold the water to go through for the boiler to heat? very confused as it says you need a hot water tank for the this boiler but yet he reckons its not connected to anything. cant remember now who changed the tank over but only just got problems, so surely it must be connected. Hope someone knows what I'm saying and can help me with this. Thank you
