I have a potterton puma combi bolier. The pressure in the bolier drops off to its lowest pressure eveytime i use the bolier, after about 3 hours of use.
Can anyone help me to solve this problem? Does anyone know what is probably making this happen and how can I solve it?
Cheers for all your help!
There is a few reasons why your pressure could be dropping
If the boiler is still working when it is on 1 bar then keep it there when i fit a bolier i would normaily put 1 to 1.5 bar of pressure in the system the pressure value will kick in if the pressure get to 3 bar and the normal working pressure is 1 bar for most combi boilers read the manual before taken action to see what the pressure should be on.
if it will not work on 1 bar and the manual says it should be higher tell me and i will give you some other reasons why this is happened
