Hi everyone,
I'm hoping someone can advise me on a problem I have with my bolier/CH system. It is a Worcester Bosch Combi Greenstar boiler.
Basically, the pressure (as indicated by the boiler) drops dramatically, but ONLY when the central heating is on. During the summer I have no problems at all. It has been like this since I moved in about 2 years ago, but has got gradually worse over time. Originally I was having to re-pressurise the bolier once a week, but now it has to be done daily, or even twice a day if I have the heating on all day. I am repressurising the bolier to approx 1.5 bar, and it is dropping right down to zero - normally when its at zero the radiators begin to crackle/gurgle which prompts me to repressurise.
All of the radiators are hot all over, so I dont think I need to bleed them.
The fact that I seem to be losing so much pressure makes me think I must have a leak somewhere in the pipework, but I cant see water anywhere, and if this was the case I would expect some leakage in the summer also?
As a bit of background information, I had British Gas out to look at the problem but they couldnt find anything wrong with the boiler itself. I also had Worcester Bosch out to replace the heat exchanger plate which was blocked up & causing the bolier to overheat when running the hot water, and I have had a power flush done by an independant company on the recommendation of Worcester Bosch. All of this was done about 1 year ago.
Does anyone have any suggestions/advice on what the problem could be?
Thanks for your help
Craig
Craig
