hi folks,
fitted trvs to all but 1 of my rads in my bungalow today, but after refilling system, bleeding rads and switching on boiler, the boiler goes into overheat and seems by sounds to be boiling, I have reduced the boiler temp from 3/4 max to now minimum this has helped a touch but to only boil up a bit later, all rads get banging hot and each time i go to bleed after an hour or so i get some but only minimum air out. Header tank in loft is full of water and no steam coming out of other pipe either. Could I have an air lock? and if so what is the best way to get rid? cannot use hose method under rads as the drains just dribbled out until i took the drain valve out all together with bowl inderneath. your help will be appreciated
Degs
Degs
