I have just replaced the valves on my radiators as 3 of the 6 were weeping causing slight loss of pressure.
Since then I have had the boiler engineer out (Halstead Ace High boiler) and he replaced the PRV and 'recharged' the expansion vessel.
We were still losing pressure but it went down to almost 0 overnight. I then discovered a leak in on of the replaced valves - it seems that the return pipe in one of the radiators was slightly thinner at the point where it was screwed into the valve and thus the olive failed to create the seal. Anyway, there was a lot of movement in that pipe so I cut around an inch off of the pipe to where it was at a regular diameter and replaced the olive - problem solved!
Or so I thought.......when the heating goes on in the morning (around 5am) the radiators upstairs are warm enough but the downstairs radiators are only luke-warm (at around 6:30am). Usually, if the heating has been on all day at the weekend the downstairs radiators are warm just after lunchtime and remain so until the heating is switched off.
All of the return valves are open fully and the downstairs TRV's are open fully.
Is my boiler too puny or could there be something else wrong?
I have bled the radiators and there isn't a temperature difference between the top or bottom of the radiators.
My living room is open plan but it's not just the room that is a bit cold - the radiators aren't particularly warm.
Any help appreciated.
