The wheel is old tech compared to hover craft and maglev.
..and each is better suited to different situations and uses. Horses for courses.
I don't agree with that
you can simply set the TRV(s) to max in that room, or remove the head(s).
3. It's also messy. If you are in a room that you are finding too warm or too cold, what do you adjust? the room thermostat? the TRV? Both? I also find that while most householders understand and operate their heating controls properly, many don't and would fail to operate such a set up successfully.
Even if you were to try and have both and set them to the exact same temperature, they are not 'identical'. Apart from them sensing different parts of the room, the work differently, one is an analogue device and other other is digital, just on/off.
Modern gas boilers are not simply on or off - with a decent control system they can modulate their heat output to much better match the demand for heat.
That may be true with a non modulating boiler, but with a modulating boiler the boiler will auto turn down output until at its minimum, at which point it will start to cycle, the anti-cycle software will increase the space time if when it fires up water returns hot, and because the boiler has switched off, when it turns back on it does so at minimum output, if an external device turns it off then it turns back on at maximum output.the room thermostat will not be satisfied and the boiler will run continually wasting energy
That doesn't really matter that you don't spend time in there, the thermostat controls the whole heating system [or half of it in your case ] so it needs to be in the best place for the whole system. If it's in the last area to warm up, TRV's in the rest of the property control the comfort in the areas where you do spend your time. The hall is generally chosen as it best fits the criteria in that for most homes it doesn't get warmed by sunlight, cooking appliances, open fires / woodburners, or even people. [Although I guess parties are not really appropriate at the moment ]it makes little sense for it to be in the hall which where we spend the least time.
Though I do understand the thinking behind where the thermostat should be, to me it makes little sense for it to be in the hall which where we spend the least time.
No need to rely on zone stats these days.
The world has moved on.
You can repeat that as often as you like, but it will make little difference.
Well to you, who likes to heat his whole house with all the doors open, no probably not.
To those who are a bit more carbon (or cash) conscious, or prefer not to rely on a stat in a cold and draughty hall to keep them warm I'd say the opposite.
Get with the now, Grandad.
