Hi folks,
I moved into a 4-bed detached house towards the end of last year which is heated by an old Glow-Worm floorstanding boiler that's probably as old as the house (~35 years old) judging by it's condition !
The boiler works fine but the problem is that it's costing a fortune to run - the bill for the three months over Christmas was about the same as I used to pay for a whole year in my previous 3-bed semi.
I've not yet decided whether to do a straight swap with a condensing boiler and keep the hot water cylinder or change to a combi/sealed system and get rid of the cylinder. I chose a Baxi Bahama for my previous house so haven't exactly had a good introduction to combi boilers ! (shudders)
With the current set-up, the hot water takes 2 minutes to reach the kitchen tap. I've not yet worked out what route that water is taking, but will hopefully sort that out when I re-do some of the pipework and radiators this summer.
In the meantime, I've got a few questions that I would appreciate some comments on :
1) Is a combi boiler suitable for a large-ish 4-bed house ? (kitchen, utility, 2 bathrooms and downstairs toilet)
2) The boiler is sited at the opposite corner of the house to the ensuite and main bathroom. Bearing in mind the delay I'm currently experiencing in getting hot water from the (much closer) cylinder, would changing to a combi potentially make this delay worse, not better, by doubling the distance and introducing an extra delay ?
3) What's the best way of working out how powerful the new boiler should be ? The current boiler has no other identifying marks on it, so I don't know the current rating.
Any comments appreciated.
Thanks.
Thanks.
