Thanks for all the replies folks. Just to compare, what is a typical flow rate from a cylindr mounted on the same floor as the bath? Is it about 15-20 l/min?
With combis, what is the limiting factor to its hot water provision, the temperature of the input water or the pressure in the combi system?
How does a combi work anyway? Does it take in cold water from the mains, heat it directly and then pump it around the house? Are the CH and HW separate i.e. if you have the CH on does that make any difference to the rate and temp at which HW is supplied?
Thanks again.
P.S. as for me being competent, I can use a spanner and can take radiators off, but I would have no intention of messing around with gas appliances. That's for the experts and the idiots.
Thanks again.
