Agile said:I thought that you should first fill from one side only and vent air from the nipple at the top of the HE ?
I also thought they automatically went into the purge mode when first powered?
Tony
Tony, If it is an 800 series then the 'perfect' way to fill it is to set 'P 6' first, this activates digital manometer on display and also sets diverter in 'mid' position.
once system is filled and basic rad venting has been done switch off mains, switch back on whilst holding + & - buttons and when 'P 0' is shown selct this. Boiler will purge rad side first then water side second.
Unfortunatley it does not auto select this on power up. The only auto air vent on these is above/behind pump.
