Boiler Service engineer left my boiler with a fault!
If it faults again just get Vaillant out under their fixed price repair scheme and if they agree it needs a pcb and a fan which I very much doubt, they will do it for around £300 and you will have a warranty, but as already said I doubt that is what was the fault
Ummm I may look into that if the boiler faults again. So far so good. That's certainly better the options I was left with, £600 repair or new boiler.
No not one error code. Just noise and eventually after a reset it heated up.
Usually an F32 code for a fan - and usually accurate. As for pcb unless it displayed an error code or kept cycling through ignition sequence then I wouldn’t be replacing that component either. I work on this boiler daily and have for years. The grinding noise mentioned earlier could be the pump.
